It is currently Thu Nov 26, 2026 11:12 am
Raised bit on engine cover
Post Raised bit on engine cover
How is the raised bit on the engine cover meant to be fixed? It isn't mentioned in the build manual but mine came with 4 L-shaped brackets 25mm wide bolted to the raised lip of the opening on the cover . The other end had been stuck to the rectangular bit with several tubes of silicone but had still come off. I've just been cleaning the silicone off the brackets and found bolt holes underneath it while the brackets look homemade but are necessary to allow clearance for the carbytooter. Are these as supplied by GTM and how are they supposed to be fixed? Obviously, I don't want the lid flying off and silicone has already been tried (and failed :roll: ), I don't suppose that a glue gun would be adequate and my fibre glassing skills are non existent so that leaves bolts (maybe dome headed stainless screws) but what method have others used?
Mon Aug 29, 2011 8:39 pm
Post Re: Raised bit on engine cover
I guess this is the raised section on the Mk 1?
Silicone will not do but a tube of proper automotive 'glue' should (tigerfix or Sikaflex) your local motor factor should have some. Parts should be clean and dry, roughed up slightly and give it a good 24 hours to dry.
Allen
Tue Aug 30, 2011 9:58 pm
Thanks, Allen. Sikaflex it is, then :)
Tue Aug 30, 2011 10:44 pm
Silicone would do it with the proper relevant primer - but this makes it complicated and expensive.
So yes, go the Sikaflex/Tigerseal route, but it is not necessary to buy a brand IMHO. Any Polyurethane adhesive sealer will do - as long as it is the curing type - some stay semi-cured and are not good.
Thu Sep 01, 2011 10:18 am
