It is currently Mon Nov 23, 2026 10:12 pm
Project Light weight [Dail up? go get a cuppa Pic Heavy]
Post Project Light weight [Dail up? go get a cuppa Pic Heavy]
Rescued from another forum...........
heres a couple of pics of what ive been upto
before mods my old front.
modded areas in wax [yellow], basically I have removed the bumper cut out and reshaped this area with some of it blended in around the lights yet still a 'chin' around the rad opening, difficult to explain.
wax painted red to get a proper look at it and lights and numberplate dropped inplace, smoothes the front out loads and gives it a bonnevile speed trail look I think
the moulding begins hope I can get it out once it is finished.
cant wait to get a bit more done, have to wait a bit tho as busy with work and other activites for a couple of weeks.
Sun Oct 07, 2007 4:04 pm
Post
Hi boys and girls well over the crimbo break I managed to get some time off work and spent most of it on the project over 15hours of just lamintaing has been done so far, plus the time preping, shuttering cutting glass mixing up etc etc so total time = LOADS
Shuttering
Its taking ages and I have now ran out of glass, time to get some more and do the last 1/4.
Sun Oct 07, 2007 4:13 pm
Post
An Update March 06
well I had what I called the Weekender a flat out weekend on the car and heres the rewards
precut glass
Gelcoat
resin
dada
one very near complete mould just a little more to do then its time to get cracking on the carbon, More updates Next Week hopefully
Sun Oct 07, 2007 4:16 pm
Post
And another update, pictures speak louder than words
Like cracking a large easter egg
Wing
A flat pack mold
Sun Oct 07, 2007 4:28 pm
Post
How much do You expect to save in weight or is the carbon for strenght & stifness?
Malcolm.
Tue Oct 09, 2007 5:13 pm
Post
My current GFRP Front weighs 19Kgs bare, and with Carbon/Kevlar being slightly Stiffer but lighter with the right layup im looking for 10Kgs, the maths suggests a little lighter but 10 is the realistic target.
Shame its all front weight as i want to loose weight of the rear, but that will come in time hopefully, will try to find the latest pictures from the camera later
Tue Oct 09, 2007 7:39 pm
Post
UpDate October 07, 2 years on since the start of this project :!:
Mold Reassembly, and the relisation that its going to need a little work to get ready/suitable for molding including rubbing some of the mold back and sorting a couple of flaws
Ready to be realeased and Braced to insure the correct width
A suitable name i think for the release wax and as a belt and braces i also used PVA release. about 6 coats of wax i lost count to be honest, then the PVA
Gel coat, this was used so that i have a suitable surface to rub back so i can paint the front.
Pre cut pieces of Carbon fibre
Layer one of Carbon, what a mad man i was trying to do this layer in the minimum number of pieces, the main part of the front is just over a meter square piece of carbon :!: wrestling to get this down as neat as possible was a struggle, plus this is wet layup which makes it even more messy and time consuming
Core in the wings, by adding a core material [foam] you can stiffen up a composite massively for minimum weight gain.
The lovely Kevlar layer, which was alot of hard work to cut, can see why its used in bullet proof vests etc.
More Carbon after putting the core material in over the central part of the front.
Finally done, notice the additional kevlar in the wheel arches, the arches have core and and extra layer of kevlar directly above the wheel, hopefully this will minimise any damage from stones etc.
A Oven :!: Insulation board of a convient size made an excellant oven quickly
And radiator, low bake at 27 degrees and a final bake with the space heater at a slightly elevated temperature.
What a project what a silly idea all this was :roll: the work involved has been imense, going to leave it in the mold for a while need a break from this again, once its out can look at fitting the mounts and working out inner arches, plus find out what it weighs.
Sat Oct 27, 2007 2:25 pm
Post
Looks good Neil. Looking forward to seeing the finished product.
Sat Oct 27, 2007 5:45 pm
Post
Very professional looking split moulds there. It's always a relief when something that size actually lets go and releases cleanly. I'm looking forward to seeing the finished article.
I bought a pair of Teflon coated shears specifically to cut Kevlar.
Tue Oct 30, 2007 9:19 am
Post
A quick update, popped it out the mold at the weekend
A few small air bubbles to sort in the gel coat unfortantly so will have to be sorted before painting etc. was a little disapointed with the bubbles but its my first attempt at this but i liked the result when i weighed it
8Kg, thats un trimmed still with peel ply on it, so with those removed, the mounts added and inner arches [once ive decided how to do them] it should beat the target weight of 10K just about :D :shock: hopefully
Oh and the flashng from the split lines is so minimal its awesome like just hair line :D
Wed Nov 07, 2007 10:27 pm
Post
So Neil, is the next step to make the rear of the car the same way?
I'd imagine you could save a fair bit of weight from doing that. Especially as the bodywork of the car from the rear bulkhead backwards is non load bearing, you could make it really thin!
Oh, and of course, the doors could be done too! :wink:
Sun Nov 11, 2007 9:37 am
Post
OK I'm going to ask a stupid question.
It's a mixture of kevlar and carbon fibre.
What the ****** do You use to cut out the head lights etc ??
Sun Nov 11, 2007 2:45 pm
Post
Fair Question,
When i layed up the kevlar i made sure there was no kevlar near the headlights and edges to be trimmed. you can cut kevlar, its a bit hard going but can be done, the main problem you have it leaves a fluffy edge. but by controlling my lay up this problem should be minimised in the trimmed areas
Sun Nov 11, 2007 11:06 pm
Post
I was going to ask "what the dickens" but I didn't want John thinkng I was taking the P out of his name :)
Sun Nov 18, 2007 5:21 pm
Post Re: Project Light weight [Dail up? go get a cuppa Pic Heavy]
Oh my, there is a few hours worth of work there! Fair effort though, producing your own mould for the front end! and then producing one in CF!
Wed Mar 05, 2008 1:41 pm
