It is currently Mon Nov 23, 2026 4:18 am
Coupe sliding window channels
Post Coupe sliding window channels
Merry Christmas everybody !
I'm planning on changing the sliding window channels on my coupe this week and was wondering what the best way to do it was?
Do I need to remove the window frame or can the be changed in situ?
Griff
Sat Dec 24, 2011 10:28 pm
Post Re: Coupe sliding window channels
No don't take the frame off. It'll never go back in the same place.
You will need to remove the chrome rail at the bottom - it should be held in with some stainless screws trough the felt/rubber channel... but who knows !
the rail and the bottom channel will then slide inwards with the windows (they need to be open). You can then replace the upper channel and put it all back!!
Sun Dec 25, 2011 1:45 am
Thanks Dino you make it sound so easy, I'm going to have a look at it tomorrow
Sun Dec 25, 2011 11:59 pm
Got the old seals out nice and quick now have to struggle getting the new ones back in.
Mon Dec 26, 2011 11:50 pm
Yes, the new ones seem more 'chunky' don't they.
Tue Dec 27, 2011 1:04 pm
Fit easily into the bottom but the top ones are tight, still at least they're not covered in mould.
Tue Dec 27, 2011 4:04 pm
All done, fitting the top one around the frame was difficult as they kept twisting. Driver side works well but passenger needs tweaking to work smoother. Looks good and no leaks.
Thu Dec 29, 2011 9:04 pm
