It is currently Tue Nov 24, 2026 5:18 am
Introduction & a few questions
Post Introduction & a few questions
Well i have taken the plunge and purchased a GTM (Mr Ibrooks on here is to blame), im more of a mini man really having a 998cc, 1275cc and a 1275 turbo engined minis. 2 members of our club have gtms so thought i would join them, ibrooks is doing a micra engine in his coupe, the other one being an A-series turbo rossa.
so now for the questions, im looking into dropping a K-series in the back of the coupe as i want speed and some reliability, and most of all comfort (well comfy from a mini).
so what are the pit falls you have found, does te gear linkge work as it should?
im sure there will be loads of questions but for now im just intrested in the proper pit falls.
thanks glyn
Fri Jan 06, 2012 7:56 pm
Post Re: Introduction & a few questions
Good luck with the project, Not sure I would undertake such major work, I suspect the gear linkage will be the least of your worries when redesigning the rear end to fit a K series.
Sat Jan 07, 2012 4:39 pm
K series is probably not the easiest. Have a search on here re Honda, Vauxhall, Toyota.
As above, the gear linkage is probably one of the easier bits :wink:
Sat Jan 07, 2012 5:07 pm
Gear linkage is easy on k series, i.e elise or MGF style all the bits are available easy
Sat Jan 07, 2012 5:49 pm
'lo Ding :wink:
I'm just a bad influence - and both you and Dave are easily led.
Tue Jan 10, 2012 10:52 pm
oh and I forgot to say
Welcome to the mad house!!!
Tue Jan 10, 2012 11:21 pm
so what engines do you recomend in the rear of such a beast? i was talking with ibrooks the other night and if i go vtech straight off you always want more power, so i thought k series start at 1.4 and build up when i get bored.
i dont like micras b4 you start brooksy!!!!
Wed Jan 25, 2012 6:55 pm
