It is currently Mon Nov 09, 2026 2:40 pm
[ 6 posts ] |
Smiths Tacho Gauge Wiring
Andy
Has anyone got any wiring information on Smiths Taho Gauges, I've been doing some research into the gauge but I'm still confused, from what I can gather there is 2 different types of gauge RVI (early) RVC (late) (positive earth/negitive earth). I'm trying to wire mine to an electronic ignition (Aldon) and believe you have to have the later RVC model to do so. Can anyone eleborate further. I believe my gauge is from a Trimpth Dolimite??? I think the gauge in mine is the same as the one shown in West's car (see forum topic "Dash")
| Sat Apr 05, 2008 8:45 am |
 Re: Smiths Tacho Gauge Wiring
Mines the later type, neg earth, and if it was connected to an A series it would be wired to the negative side of the coil. i think from memory, best grab a mini wiring diagram that would confirm which terminal of the coil to connect the tach too,
| Sat Apr 05, 2008 10:25 am |
the other Tim
I'm pretty sure its the negative side of the coil, the positive is just a live feed switched by the key
| Sat Apr 05, 2008 12:04 pm |
Andy
Thanks for that, I've just checked mine and it's a RVC type negitive earth so it OK for electronic, I was just a bit worried as mine had the old style terminal points rather than the shown 3 side by side and thats why I thought it was wrong. I have another question to do with wiring, have you got a decent drawing of the indicator setup. I have down loaded numerous ones from the net but I still have problems in getting the dash warning lights to work. The rest of the system works perfectly (hazard/hazard warning lights, indicators) but as soon as I try and connect the indicator warning light from the Triumpth centre cluster to the flasher I get either a solid light or a light that remains on even when the indicator is turned off. I have tried a 3 pin flasher but the 3rd pin had no supply?? Do you think its just a faulty flasher??? The hazard warning light is sperate to the indicator warning lights. Any ideas would be appreciated.
| Sat Apr 05, 2008 7:27 pm |
gtmdriver
You've probably thought of this but are you sure it's not from a 6 cylinder Triumph? If it is it'll read wrong.
I used a Dolomite gauge too but I had it re-conned by Speedy Cables.
If, for any reason, it doesn't read correctly they can re-calibrate it as needed and also adapt it so that it can be triggered from different types of ignition systems.
_________________ GRP rules!
| Sat Apr 05, 2008 10:55 pm |
Andy
Thanks for that, yeah mines a 4 cylinder one so I've wired it up and will see how it goes, I orignially thought mine was the early RVI type not and RVC. Fingers crossed all is OK.
| Sun Apr 06, 2008 8:51 pm |
[ 6 posts ] |
