It is currently Mon Jul 13, 2026 11:02 pm
Coupe dash removal
Post Coupe dash removal
I am wanting to remove the dash of my car in order to sort a few electrical gremlins and tidy wiring up, so would appreaciate advice on how best to do this, so I can spend the bare minimum of time upside down with my head in the footwell, as it does tend to attract smart **** comments.
Many thanks.
Mon Apr 07, 2008 12:49 pm
Post Re: Coupe dash removal
Mine was held on by some bolts on the outside of the car, but as I still keep on finding with mine, is that it is far from standard and there may be other ways that they were attached.
They were located just above the hinges, so should be easy enough to find.
If you are doing loads on the dash, then it may be worth removing the column, so that you can get to everything easier. You'll have to play it by ear though.
Mon Apr 07, 2008 1:05 pm
removing the column will make life alot easier to remove the dash,
Mon Apr 07, 2008 3:21 pm
