It is currently Mon Oct 26, 2026 6:56 am
Help with parts for steering arm locking!
Post Help with parts for steering arm locking!
Pulled the arms that lock the rear steering to change out the tie-bar ends. I discovered that one is a stock Mini one, and the other one (inner side on the subframe) is reverse threaded and has a larger shaft.. see the pic.. can anyone tell me what car the inner ones are from? The larger reverrse thread one is at the top of the picture.. Thanks
MiniMike in Victoria
1989 GTM Coupe - SOLD
1989 Mini 30 VTEC powered
Sun Jul 29, 2012 3:19 am
Post Re: Help with parts for steering arm locking!
I have changed the system on my car, but prior to that with a system like yours they were all just standard track rod ends.
David
Land Rover Freelander 2
BRA 289 Cobra replica
Porsche 968 Coupe
Radical PR6
Sun Jul 29, 2012 8:39 am
You might want to have a look at this thread;
locking-up-the-rear-steering-t2195.html
Sun Jul 29, 2012 11:19 am
I have searched and read the other threads, but I can't find mention of what car the inner track rod end comes from. It is definitely not from a Mini. Both the tapered shaft diameter and the threads on the shaft are larger.
Sun Jul 29, 2012 4:41 pm
http://www.gtmdrivers.com/forum/post8037.html?hilit=austin#p8037
Seen this one?
Sun Jul 29, 2012 7:00 pm
Nope, didn't find that one.. so not so good on my searching then! Thanks Neil.. I'll drop Alan a line to see if will send them off to Canada... Cheers
I assume the setup is the same for Rossa as the Coupe then??
Sun Jul 29, 2012 7:22 pm
Ala has looked after me and the tie bar ends are in the post! Thanks Alan!
Sun Aug 12, 2012 3:35 am
Parts have arrived..just have to throw them on the car..
Wed Aug 22, 2012 5:31 am
