It is currently Sun Jun 14, 2026 10:16 am
[ 6 posts ] |
baxter
 steering wheel
hello again, does anyone know if the steering wheel is the same fitting/splines as the mini one, i like the idea of the flat bottom ones, also does any one know what the steering column cowl is from as i dont have one and haven't seen on fitted. cheers.
| Fri Jul 15, 2011 7:55 pm |
dbanes
Joined: Thu May 26, 2011 8:45 am Posts: 91 Location: Bucks, UK GTM: K3
 Re: steering wheel
Yes same as a classic Mini, unless someone tells me other wise, even my K3 appears to have a Mini setup.
_________________ David Banes GTM Owners Club Member 1258 http://gtmrossak3.org
| Fri Jul 15, 2011 9:15 pm |
RaymondH
 Re: steering wheel
dbanes wrote: Yes same as a classic Mini, unless someone tells me other wise, even my K3 appears to have a Mini setup. Yup, agreed. If your car has the column intended for it then it's from an Allegro and will take any Mini steering wheel. The stalks are also the same as Mini ones and are available new from Minispares if you should ever need them.
| Sat Jul 16, 2011 1:11 pm |
baxter
 Re: steering wheel
thankyou guys. I know what mini parts to save now when i can get in the other garage.
| Sat Jul 16, 2011 5:52 pm |
peter204
Joined: Thu Mar 29, 2012 12:03 pm Posts: 78 Location: Lichfield, Staffordshire GTM: Rossa
 Re: steering wheel
I know that this is a very old discussion thread, but I have a related question.
Is the ignition switch on the Allegro steering column the same as a Mini column-mounted ignition switch? They look similar from 'photos on the internet, but I don't know if they are interchangeable.
I have recently started work on a Rossa II which has been off the road for a good many years. The ignition switch is faulty and, despite a fair bit of contact cleaner, refuses to work. I'm looking for a replacement and cannot find one anywhere. I'm beginning to think that, if you every see Lord Lucan riding down the street on Shergar, then he's probably got an Allegro ignition switch with him!!
Regards, Peter
| Thu May 02, 2013 5:51 pm |
peter204
 Re: steering wheel
Given up on the column mounted ignition switch and bought a dash mounted one.
_________________ ----------------- GTM Rossa II SLK350 GTMOC member 554
| Sat May 18, 2013 10:31 pm |
[ 6 posts ] |
