It is currently Tue Oct 27, 2026 10:17 am
gearchange
Post gearchange
Just wondering if any of you mad people out there have come up with any magic tricks for the gear change, mines got the original chopped up remote system, managed to get if fairly free but there still feels like there will be too much drag in it to work nicely ! !
Fri Jun 14, 2013 1:04 pm
Post Re: gearchange
Got a pic of the remote system memory is fading me on how they look? I know how I would convert a rod change to cable. My Honda engined coupe is rod change and I have converted it to cable and it has been one of the best things I have done, so much slicker.
Fri Jun 14, 2013 8:05 pm
Post Re: gearchange
I will try and take a couple pics and post them on .
Sat Jun 15, 2013 7:29 am
Post Re: gearchange
Cable gearchange sounds good. Did you use parts from an MGF or something similiar?
Sat Jun 15, 2013 1:45 pm
Post Re: gearchange
Here is a drawing of the shift linkage..
MiniMike in Victoria
1989 GTM Coupe - SOLD
1989 Mini 30 VTEC powered
Sun Jun 16, 2013 3:04 am
Post Re: gearchange
ive got a spare if you need one :D
Sun Jun 16, 2013 7:38 am
Post Re: gearchange
I would like to understand how you did that.
David
Land Rover Freelander 2
BRA 289 Cobra replica
Porsche 968 Coupe
Radical PR6
Sun Jun 16, 2013 9:04 am
Post Re: gearchange
That is the 'rod change' linkage - the 'remote change' was the early system which used a cut down Mini Cooper S 'remote' extension.
Sun Jun 16, 2013 9:55 am
Post Re: gearchange
Just thought I'd remind everyone that you can't use a later rod change system with the early solid remote type box and vice versa -- it reverses the change -- been there done that!
Mon Jun 17, 2013 11:20 am
Post Re: gearchange
Hopefully improved , a good spray with a spray grease seems to have improved things. , gearchange , tick !! Everything else still to do !!! :lol:
Mon Jun 17, 2013 3:50 pm
Post Re: gearchange
Just looked at this again and the key element missing is the detail of part I -- I think there was a was a small forging bolted to it pointing forward that had a ball end to it -- tube E could then slide back and forth on it if it was well greased. It was important that this part and the rod input to the gearbox were in alignment.
Wed Jun 19, 2013 5:39 pm
Post Re: gearchange
It is shown - just not in any detail. Part E is a sliding fit over the bar that projects forwards from the bottom of part I. As it happens H and I on mine were welded together (and looked like they always had been) so they were just one part.
I'm going to be making a copy of West's cable linkage for the Micra engine (which should be going into a subframe over this coming weekend). I've got an MGF selector and cables as a basis already.
Iain
Thu Jun 20, 2013 12:44 pm
Post Re: gearchange
For my gear change I looked at elise and MGF and combined what I felt the best of both systems, I liked the cable arrangement of the MGF. The Elise uses a bel crank under the engine which I was not keen on due to the increased moving parts/points of wear.
I used custom marine spec cables which are ptfe lined and very little back lash and this combined with the Focus rs gear lever/box gave the cable movement I wanted and being the metal version was easy to modify to fit for my requirements.
The cables wer expensive but it made a huge differance to my car and helpped alot with more consistant performance at the track I use to miss gears with the old system when running hard with the nitrous.
Thu Jul 04, 2013 12:53 pm
