It is currently Thu Apr 23, 2026 1:34 am
[ 3 posts ] |
RaymondH
 A Series Front Plate
Do I need to drain the oil before I remove the engine front plate (the one behind the timing gears)? I have an oil leak in that area and suspect that it's coming from between the plate and the block so want to change the gasket and it also has a bolt hole that needs retapping. Thanks.
| Sun Jun 16, 2013 8:20 pm |
gtmdriver
 Re: A Series Front Plate
No.
A small amount of oil will come out when you take off the timing chain cover but the oil level in the sump should be well below crankshaft height.
_________________ GRP rules!
| Sun Jun 16, 2013 8:44 pm |
RaymondH
Great - thanks
| Sun Jun 16, 2013 9:39 pm |
[ 3 posts ] |
