It is currently Sat Nov 14, 2026 6:08 pm
Coupe engineering drawings
Post Coupe engineering drawings
Hi has anybody got a set of coupe chassis/body dimensioned drawings with enough info to start making a chassis? :)
john
Fri Feb 07, 2014 3:00 pm
Post Re: Coupe engineering drawings
I've got one or two but by no means a full set.
You're welcome to a copy of what I have.
Fri Feb 07, 2014 7:49 pm
Hi Driver, please mail me to jtbunting44@yahoo.co.uk, lets see if I can get started :roll:
Sat Feb 08, 2014 4:34 am
Done.
Sat Feb 08, 2014 10:09 am
Many thanks now for a little weekend study :D
Sat Feb 08, 2014 10:12 am
John,
You have a PM
Regards,
Sat Feb 08, 2014 3:56 pm
Actually I don't.
Give it another try.
Sat Feb 08, 2014 5:22 pm
Gtmdriver it was to the other John. Sorry for the confusion!
Sun Feb 09, 2014 2:36 pm
john
John,
When you say a chassis, do you mean the steel tub or are you talking about a tubular spaceframed chassis?
David
Land Rover Freelander 2
BRA 289 Cobra replica
Porsche 968 Coupe
Radical PR6
Sun Feb 09, 2014 5:31 pm
It was to make a space frame with integral roll cage
Mon Feb 10, 2014 4:39 am
I like the idea of that.
David
Porsche 968 Coupe
Radical PR6
Mon Feb 10, 2014 8:10 am
The twinny Mini I built here in Kano used the roll cage in the back to carry the rear subframe as there was just a big hole where the rearseat and boot floor used to be, so its just an extension of that idea and if possible remove the sub frames as well using coilsprung suspension :)
Mon Feb 10, 2014 9:21 am
My Kermit car is spaceframed at the back and sort of modified at the front but still uses the heavy tub in the centre. It weighs a total (with everything except me) of 600kg which is light but not light enough.
Will you be getting this chassis built in the UK or overseas?
David
Porsche 968 Coupe
Radical PR6
Mon Feb 10, 2014 10:55 am
Most probably make it here as I did with the Twinny roll cage, shiping things back can be very costly and often goes wrong with our greedy thieving customs, who believe bribery and corruption is the way to go :x I am looking at a space frame that could be adapted and weighs 115Kg but still negotiating transport and clearing this end.
After my November shipment stuck in port "still" all I have is my 2 x 14 twinny donor car :(
john
Mon Feb 10, 2014 11:07 am
i have the drawings that i made over last 3years from measurments of a 1.3
Thu Feb 13, 2014 6:07 pm
