It is currently Fri Oct 30, 2026 7:56 am
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
Paint
Post Re: Paint
gtmdriver wrote:
If it's under the primer than it could also be traces of release agent from the moulding process.
When I got the car it was covered in micro blisters but no sign of large blisters as I have now and it appeared to have been rubbed down and painted before and it got a very good cleaning before the primer!
(Gulf) GTM Coupe
Fri May 16, 2008 6:15 pm
Post Re: Paint
When you say you can see the fibreglass, is that the gelcoat or the matting :?: Do the blisters have fluid in them :?:
Fri May 16, 2008 10:45 pm
Post Re: Paint
Tim, The blisters are dry and i think its the matting as this car has very little gelcoat (all,the red was paint), having been rubbed down and painted so many times in its life! :? :|
(Gulf) GTM Coupe
Sat May 17, 2008 5:45 pm
Post Re: Paint
Alex,
The blisters are dry which is good, i was trying to out find if the gel and matting are parting company or as John suggested there is a paint reaction going on. I have to take my daily drive to my local bodyshop shortly, he does a reasonable number of kit cars and bodywork for some race cars (regularly :!: :!: :lol:) so has some fibreglass experience. Maybe he'l have some thoughts.
Sat May 17, 2008 7:22 pm
Post Re: Paint
I had an informative chat with Chris (my local bodywork guru :lol:) today regarding fibreglass, paint etc. When he paints old fibreglass of unknown paint history the first coat is a sealer (not primer sealer) this is NOT rubbed down before applying a suitable primer as that would affect the integrity enableing old paint to bleed through and possibly react :( Once the topcoat has been applied water should'nt be able to creep into the fibreglass, but apparently its not unknown for moisture either from the atmosphere, rain in wheelarches etc to be absorbed through the the underside of some older fibreglass with unpleasant results :shock: :shock:
No two pack should have been produced after the end of 06, its still possible to get bits from here and there, hardener is getting in very short supply. Not all countries opted out of using two pack, Australia being one (i'm sure there others nearer) but if you're caught importing it its almost as bad as being a drug runner :? :shock: :roll: He seemed to think there is a range of commercial vehicle paints (Du Pont :?: :?: ) thats quite similar to the old two pack, not quite as tough though.
The above is not cast in stone, its just what works for him :wink:
Thu May 29, 2008 7:12 pm
Post Re: Paint
My local supplier is getting fresh deliveries of 2 pack paint on a regular basis and expects to be doing so for some time to come. Is it all old stock?
Thu May 29, 2008 8:33 pm
Post Re: Paint
John, i would assume so, Chris buys his paint from Movac, they told him awhile ago that they would'nt be getting any more hardener, then they had another pallet delivered, someone bought half of that immediately, so who knows. It would'nt hurt to ask your supplier. I think it would be wise to stock up just to be sure :wink:
ps, we are both talking about the paint that contains isocyanates i presume
Thu May 29, 2008 11:20 pm
Post Re: Paint
Yes.
I'm surprised at this because currently even water based paint still needs a 2 pack lacquer over it to protect it, and water based primers are still not good on steel as it causes rust.
Fri May 30, 2008 8:57 am
Post Re: Paint
I presume the lacquer used over water based paints does'nt contain isocyanates, i'll quizz him further when i see him at the end of next week :D
Fri May 30, 2008 10:50 am
Post Re: Paint
Had another word today, isocyanates are'nt the problem, in fact they are probably in the latest type paint mix's. Its the solvents in the thinners (does'nt matter if the sprayman dies due to the arsnic :roll: :? :!: ) Basically they are trying to eliminate most thinners, hence water based paints, they can't make water based lacquer yet but they're not diluted (high solids, one dust coat then main thick coat as opposed to three coats of lacquer over the old 2pack) Its a total minefield with Defra (Deathreat :lol: ) the driving :?: force :!: :?
Fri Jun 13, 2008 8:28 pm
Post Re: Paint
Does anyone know the paint code that is the closest match to the original red? I know i'm very boring sticking with red.
Wed Sep 09, 2009 12:15 pm
