It is currently Sun Aug 23, 2026 7:07 am
Doorcatches
Post Doorcatches
Hi guys,
My doorcatcher on the drivers side is a bit loose, I want to put it a bit more to the inside of the car so the door will close better and tighten it.
But how o how, on the backside there seem to be two nuts which I cannot reach. So I can keep turning the two screws but they wont tighten Because the nuts turn with them...
How did they ever fit them and how can I reach for the nuts?
Thanks in advance
Greets Harold
Sun Dec 27, 2015 12:29 pm
Post Re: Doorcatches
Hi Harold.
You should have and access hole just above the level of the sill behind the seat to get to the 3 bolts holding the body to the chassis, you should be able to get a spanner up there, I made my access holes bigger and triangle shaped.
Just be careful when reaching for your nuts, don't let people catch you doing it :oops:
Sun Dec 27, 2015 4:37 pm
Hi John,
I found the hole, it was glued away behind the carpet.
After a struggle with hard to reach nuts of unknown size, irritating isolation and a very small hole I'm a happy man, the doorcatch is where I want it and the screws/nuts are tightened.
A tight hole is not always pleasant... :wink:
Thanks,
Harold
Sun Dec 27, 2015 6:40 pm
I should have said 1/4" countersunk screws needing an 11mm spanner (i think) for "your awkward nuts"
Mon Dec 28, 2015 6:08 am
I went the british way and took an imperial spanner, I believe it was 3/8", after all it's a car with british roots.
Better get a spanner that fits well instead of one that nearly fits and you end up with round nuts... :wink:
Mon Dec 28, 2015 4:34 pm
Hi Harold,
In spite of tight holes in hidden places and loose nuts, you got the job done :lol:
Tue Dec 29, 2015 4:21 am
maybe it is time to think about captive nuts?
Tue Dec 29, 2015 10:38 pm
Mine are tack welded to a backing plate :roll: and I know where to find them :lol:
Wed Dec 30, 2015 4:17 am
ouch.... :shock:
Wed Dec 30, 2015 9:58 am
Has Max Miller taken over this thread?
Youngsters will need to google, it's the age that does it :)
Wed Dec 30, 2015 4:50 pm
Did Max ever have a coupe? with those tight trousers not easy to get in :lol:
Thu Dec 31, 2015 4:40 am
