It is currently Mon Nov 23, 2026 12:09 am
Front indicator lights k3
Post Front indicator lights k3
Anyone know where they come from?
Sun Sep 11, 2016 2:12 pm
Post Re: Front indicator lights k3
The front indicators and the Aux lights come from a Ford Sierra Mk1 Cosworth, they are originally mounted in the bumper.
The indicators are available in clear and amber as I think they are fitted to Ford Sierra Mk1 3 door Cosworth/XR4i/XR4x4/Ghia & Escort Cosworth found on flea bay at about £25 per pair
and the aux lights are expensive they sell at about £50-£100 each when they are available.
Lots have said that there are replacements but its finding ones that fit right, or bond over the hole and put you own combo in.
Hope that helps, sure others will be along to tell us more about replacements.......
The owner isn't
Sun Sep 11, 2016 6:17 pm
Many thanks for the info.
Sun Sep 11, 2016 7:34 pm
Btw - how do you get the old indicators out ? There's only a small hole on the inside where the wires go through - can't even get to the bulb!
Sun Sep 11, 2016 10:31 pm
Hi,
With mine don't know if they are all the same, inside the clam shell there will be 4 nuts and washers near the indicators and aux lights.
undo those and this releases the lights from the back, the lights are held in with threaded bar which is looped throgh the fixing points of the lights.
Hope that helps
The owner isn't
Sun Sep 11, 2016 10:48 pm
That would be the sensible way - mine look like they've been glued in. Time to get the dremel out!
Mon Sep 12, 2016 9:34 pm
Have you any aux lights as they hold them in too.
The owner isn't
Tue Sep 13, 2016 3:37 pm
