Re: front subframe bottom mounts
the other Tim wrote:
My Coupe is 1990 and uses the old solid mount subframe too.
OK, that confirms that GTM didn't change the tub. So Tim (the other, other Tim!) 'should' be using the earlier subframe.
I would think that if you're converting to the later type subframe the solid mounts would be required to take up the gap between the "legs" and the floor as i do'nt think the Mini bulkhead/floorpan was redesigned
Ah well sort of!
Agreed the later subframe needs the mounts, either oem rubber or aftermarket solid, to fit in a Mini...but even so.... the later subframe mounts to a different part of the bulkhead on a Mini from the original design.
The early type attaches around the area where the floor meets the bulkhead, like on the coupe. But the later type mounts further up on the bulkhead, almost in line with where the rack comes through. There are a couple of strengthening plates welded to a later Mini shell here as it's a bit of a weak area, there are often cracks here.
Now this changed mounting position doesn't matter on a Mini, as of course the later frame/mounts were designed to fit the existing Mini shell, the holes are just drilled in a different place, but a coupe bulkhead is a different shape from a Mini so there's no guarentee that the new mounting position of the later subframe will line up with anything useful on the GTM.
