It is currently Wed Apr 22, 2026 6:42 pm
Shock absorbers
Post Shock absorbers
Can anyone tell me if the shock absorbers are standard length or shortened on the GTM Coupe?
Mon Oct 23, 2017 10:58 pm
Post Re: Shock absorbers
Mine runs std length, I can't see anyone ordering or providing short throw units especially as the donuts do a certain amount of damping inherently.
Tue Oct 24, 2017 12:09 am
I figured they would be the standard length ones, just crossed my mind when I saw these options
Standard https://www.minisport.com/gazgta231b12-gaz-adjustable-mini-shock-absorbers-front-each.html
Lowered https://www.minisport.com/gazgta236b12-gaz-adjustable-mini-shock-absorbers-front-lowered-each.html
Tue Oct 24, 2017 8:46 pm
I stand corrected.... But still, I'd use standard ones.
Tue Oct 24, 2017 11:11 pm
Yep I run Standard length too. you just have to watch full bump if you have trimmed your bump stops at all and run very low.
if you fit the shorter ones, there is a good chance you will limit the rebound travel and bottom out the shock rather than the rebound buffers from memory.
This all assumes standard GTM mounts and Mini parts
Wed Oct 25, 2017 8:53 pm
