Re: GTM COUPE STEERING COLUMN
I also did my own, using a steel tube with 2 bushes at either end. Fixed to the column support with u bolts
I then fitted a MGF collapsible column between that and the cut down section of the original column that fits into the rack
That has 2 benefits, you can fit the column straight and it is safer in the event of a shunt!
Simon
