It is currently Sat Nov 14, 2026 10:48 pm
Any spare ARB's
Post Any spare ARB's
Does anybody have a front ARB or recommend an alternative that could possibly be adapted to fit?
In the garage costa del Telford
Mon Sep 30, 2019 7:11 pm
Post Re: Any spare ARB's
I think thats a big hope right there :lol:
Colin
Spin up the Rotrex
BMW 440d M Sport x drive
BMW 320d M Sport
Tue Oct 01, 2019 9:56 am
Thanks for the help. :|
Tue Oct 01, 2019 10:02 am
These really are rarer than rocking horse doings with hens teeth stuck in it......
Its now a case of getting them made, try Dave Gallop at track Developments.
Tue Oct 01, 2019 7:00 pm
Definitely not going to find these second hand, get them made is your only choice mate. I had mine made one off, but Alan gow is probably retired now. I can find you a contact number or email if you want though
Colin
Spin up the Rotrex
BMW 320d M Sport
Tue Oct 01, 2019 9:44 pm
If you are able to get new ones made up. Could you post details of price and availability as I could do with a front ARB
Wed Oct 02, 2019 1:19 pm
Just one word! Spanners!
Wed Oct 02, 2019 6:07 pm
i had some made by Alan Gow a long time ago which was very difficult to get him to answer phone i later found out they had been made the wrong size the front was 19mm and rear was 20mm both should be 18mm so i contacted tube bender ltd as seen in complete kit car he only had tooling to do 16mm the rear one was the one that i thought would be a problem as most i have seen are set on softest setting on 18mm bar so i thought 20mm could cause over steer and didn,t fancy being being over taken by the back of the car so i drew around 20mm bar and sent drawing to tom at tube bender he bent me a 16mm one and i made the end plates with the adjusting holes for the drop links to weld on i have kept 19mm front as this is close to 18mm but car not finished so not driven yet 16mm rear cost £90 inc vat ok but material used was not ideal was not perfectly round so not ideal where d bushes fit. I could do a drawing of one of may rears if anyone wants one but the front will be more difficult as it is on the car at the moment
Wed Oct 02, 2019 10:59 pm
A smaller rear bar makes sense with the factory suspension. Rear bar is always set softer than front. I have driven my Spyder with rear bar disconnected and front bar set quite stiff and was still acceptable.
I believe it is a different story with Z Cars rear suspension fitted. Lower roll centre and less camber compliance helps rear grip so a stiffer rear bar setting is needed to eliminate understeer.
Wed Oct 02, 2019 11:13 pm
Sounds like i might have got lucky with my ARB's from alan gow because i have the Z cars rear suspension. Either way i think it handles like a dream :lol:
Colin
Spin up the Rotrex
BMW 320d M Sport
Thu Oct 03, 2019 11:35 am
