It is currently Wed Jun 17, 2026 12:03 am
Cox gtm Clutch and Brake Master cylinders.
Post Cox gtm Clutch and Brake Master cylinders.
Hello All,
Just been informed by a GTM owner of a brake failure to his car caused by the bonnet rubbing on the top bend out of Master Cylinder on older type set up and caused him to loose brake fluid therefore his brakes, just checked ours and exactly the same when you look under you can see them hitting bonnet, ours is not on the road yet so we can modify, either re-plumb or realign the bonnet somehow, so please be aware all out there, KEN HIND.
Sat Jan 09, 2021 2:05 pm
Post Re: Cox gtm Clutch and Brake Master cylinders.
This was my solution, plenty of clearance now.
Sat Jan 09, 2021 5:35 pm
I also went the banjo route
Mon Jan 11, 2021 6:05 am
Thank's for info, should have thought that one out, it,s obvious when your shown it, great pics, thanks again will get organised with that one, Cheers, KENHIND.
Tue Jan 12, 2021 6:41 pm
Thanks again for info, but I am having trouble sourcing the banjo fitting as shown, is there anyway you can give me the info so I could order, sorry to a pain, Cheers, KENHIND.
Wed Jan 13, 2021 6:11 pm
Hi again, I think I have just located one on the Charles Ware Morris Minor site, but would still appreciate answer to my previous post, Cheers, KENHIND.
Wed Jan 13, 2021 6:15 pm
Rimmer Bros
1 7H7851 UNION BANJO
1 C5192A BOLT-BANJO
1 233220A COPPER WASHER
1 538532 COPPER WASHER 7/16
Wed Jan 13, 2021 9:06 pm
Hi Ken (555)
Please can you show a picture of your bias bar setup, there is only a glimpse of it in your master cylinder picture. Only curiosity mine is already installed.
Thu Jan 14, 2021 6:26 am
I'll get some pics to upload.
But its one of these, https://kentautodevelopments.com/products/kad-adjustable-brake-bias-pedal-box
Thu Jan 14, 2021 9:59 am
Click for bigger pics
Thu Jan 14, 2021 2:00 pm
Thanks ken looks neat, with a push rod of the original brake peddle up to the bias bar, easier to adjust than my home made adaption of the peddle box
john
Thu Jan 14, 2021 2:18 pm
yes, a rod down to the brake pedals.
Fitted the other way around from what it would be in a mini, the master cylinders would be out over the engine bay.
Thu Jan 14, 2021 3:25 pm
Thanks for replies, great info KEN555 will get sorted soon, Cheers for help all :D
Fri Jan 15, 2021 1:29 pm
