It is currently Mon Nov 23, 2026 5:18 am
Heerey fuel tank
Post Heerey fuel tank
Hi everyone, I am looking for a fuel tank to sit in the Vee of my Heerey GTM, does anyone have one they would sell? Thanks
Fri Apr 01, 2022 8:54 am
Post Re: Heerey fuel tank
Hi Andy,
I made a steel tank to fit in my old Cox long ago and worked well until rust got into carbs, my current car had an alli tank made by Jedi Race Cars after supplying a cardboard template, the Vee tank was never a standard from Cox, Heerey, etc, back in the day a Mini tank was used, or a rectangular tank sitting in the front subframe with a place to fit the spare wheel on top.
If you have a local welder/fabricator and supply with card templates that's about the only way you will get a Vee tank
Sat Apr 02, 2022 6:34 am
I have found someone that can make me an alloy tank for the vee, it’s a great use of space.
Sat Apr 02, 2022 9:28 am
Good idea to make an alloy tank.
Just for the record I have a Heerey coupe, K registration, that has a steel fuel tank in the vee.
It was fitted from new as a standard option.
AndrewC
Fri Apr 15, 2022 4:05 pm
What is the capacity of the Tank that sits in the vee?
Got a vague memory of 10.5 gallons?
Sun Apr 17, 2022 11:14 am
I have a GRP one that that sits in the Vee, came with my Heerey, I am replacing it with a 4 gallon alloy one that sits in front of the rad, but TurboCox has already has bagsies on it.
If he ever comes to collect it... :D
Tue Apr 19, 2022 11:26 am
GRP tanks can be attacked by alcohol in petrol, I'm sure there was a ban on production bikes having grp tanks for this reason. so be careful!!
Wed Apr 20, 2022 6:21 am
He only wants it as a template I think! I was going to chuck it in a skip!
Wed Apr 20, 2022 4:36 pm
I’m still hear, :wink:
Thu Apr 21, 2022 9:23 am
Send us a text when I can come get it. :D
Thu Apr 21, 2022 11:08 am
I measured the Heerey Vee tank and it seems to have a capacity of 35 litres which is approx. 7 imp gallons (90% full) or 8,5 US gallons (90% full). A new tank could be made slightly taller getting a 2-3 imp gallon increased volume.
I thought it was a good position when I bought the kit, now I don't know if I want 7 gallons of petrol in front of my face. Also full that's 40 kg extra weight at a high roll centre.
Probably an alloy tank mounted low in the front subframe is a better option.
AndrewC
Fri May 06, 2022 3:16 pm
Touche TC! Once I can actually get back in the workshop I'll be in touch...
Mon May 09, 2022 12:58 pm
AndrewC
This is how I did mine, though it is only 4.5 Gallons
Mon May 09, 2022 1:01 pm
:wink: 8)
Tue May 10, 2022 7:56 am
I can vouch for ethanol eating into a glass fibre Heerey V tank - it basically unglued the top half from the bottom, entire seam popped open on two sides. However, fixed by using an epoxy tank coating, which resists ethanol.
Sun Sep 25, 2022 12:04 pm
