OzKen
 Front & Rear Camber
Hi, Please can anyone advise as to how to achieve negative camber on my front wheels? If anything I have slightly positive camber! Thanks! Ken
| Mon Nov 21, 2022 5:50 am |
kano nordie
 Re: Front & Rear Camber
Hi Ken the traditional way was to cut the bottom arm and re-weld it back together after extending 1/4" You can now buy adjustable bottom arms, MiniSpares do nice ones which I bought and fabricated copies to have similar front and rear. pos camber will make your front end very unfriendly!! John
| Mon Nov 21, 2022 7:08 am |
OzKen
Hi John, Thanks very much for that. I’ll get onto Minispares for sure for the adjustable type. Whilst I have your kind attention, I now have a problem today with the rear custom wishbone! The rubbers have failed in the single end of the wishbone where it attaches to the subframe! Damn! Are these standard or special to GTM? Really appreciate all of this advice! Cheers Ken
| Mon Nov 21, 2022 10:42 am |
OzKen
Not sure if that photo was uploaded correctly!
| Mon Nov 21, 2022 11:11 am |
kano nordie
I think they were an off the shelf Silentbloc bush, but at my age memory is not so good. I modified, but ended up not using my set of GTM A frame arms, by using Minispares threaded ends off their neg camber adjustable bottom arms, this would have given me camber adjust on the A frame arms. I ended up using adjustable Minispares copies and a locking steering arm, giving neg adjust plus toe in adjust. John
| Mon Nov 21, 2022 11:45 am |
OzKen
Thanks very much John. I’ll try and track those bushes down. So although I’ve just got my plates, I’ve now gone backwards and off the road again! Doh!
| Mon Nov 21, 2022 12:24 pm |
kano nordie
Just think Ken instead of scaring the pants off you and being all over the place, next drive may be enjoyable John
| Tue Nov 22, 2022 7:03 am |
kano nordie
Just a thought, it may be worth looking for a PU bush of the same size
| Wed Nov 23, 2022 7:08 am |
grizzler73
You can get the bushes from Derek Hambly, Austin A55 I think, I did a adjustable wishbone with solid mounted carrier, I don't like the "bearing" version, scary! https://imgur.com/gallery/k7g36
| Wed Nov 23, 2022 2:52 pm |
OzKen
Hi John & Grizzler! Thanks very much for that. I do agree re the bearing version bring scary! Hopefully, new bushes will give me a more confident ride! Thanks again for your help Ken
| Thu Nov 24, 2022 1:10 pm |
