It is currently Fri May 01, 2026 12:23 pm
Rear window
Post Rear window
Can anyone advise what to use to glue the rear screen in on the K3 hardtop? mine is about to fall out :shock:
Fri Oct 03, 2008 1:38 pm
Post Re: Rear window
Silicone rtv. But make sure you use a primer.
Fri Oct 03, 2008 1:43 pm
Sikaflex will do the job if you're sure you'll never want it out again.
I used it to glue the perspex rear side windows in this.
Fri Oct 03, 2008 5:12 pm
I used this gear (320159250443 on ebay at the moment) on the Quantum to fit the side screens and rear screen. (needed two kits to do all windows but one kit would do the rear of a Rossa).
You clean everything up nicely and then paint on a boarder on the inside of the glass (I used packing tape to get a fine straight edge on the black banding). Once the black banding has dried you squeeze on the adhesive to the frame and then press the glass into place (one hour later it is set, however I left it for a couple of days to be sure).
Since doing the Quantum we have had no leaks whatsoever and it looks like a pro job.
Good luck and let us know what happens as I will need to do the Rossa myself sometime when I start to rebuid it.
Fri Oct 03, 2008 10:07 pm
