It is currently Sun Nov 22, 2026 5:30 pm
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
Project Light weight [Dail up? go get a cuppa Pic Heavy]
Post Re: Project Light weight [Dail up? go get a cuppa Pic Heavy]
Most impressive.
What foam core material are you using and where did you get it from???
Similarly what type of resin?
With thanks
Tue Oct 07, 2008 11:25 pm
PKR wrote:
Most impressive.
With thanks
Well I did alot of research into the resins that were most suitable for wet lay up, and it was a SP sytems epoxy resin, ampreg 22 made specifically for wet lay up and is used for Surf boards etc acording to the sales lit, and i choose the extra slow version which had its advantages for how i wanted to layup the front.
the foam core was a poly something, cannot remeber and havnt the note at hand, it was a closed cell foam, i wanted polyuerathane but i could not source that in thin sheets, i was looking for 2mm, the foam was found when looking around my parents place and its usually used under the floor for laminate flooring! it was the closest foam to the spec i wanted and was easily obtainable. was nicely flexible to form to the double curvature, and the idea of a core is to add bulk not to carry any real load itself
Tue Oct 21, 2008 8:44 pm
