It is currently Mon Nov 09, 2026 2:40 pm
Gear linkage
Post Gear linkage
Has anyone got any info on the Coupe's gear linkage? I have got the front half of one, but it is missing the bar that loops underneath the engine. Half of the brackets are missing, where it attaches too.
Measurement of all the bits would be of great help.
Cheers :D
Thu Dec 20, 2007 8:37 pm
Post
Tim,
I'm pretty sure i have all design measurements, i'll see if i can dig them up :)
Fri Dec 21, 2007 9:26 am
Post
Do you have the support bracket which attaches to the gearbox at both sides and provides a rear pivot point for the linkage. Obviously mine's on the car now so detailed measurements are not on but that rear bracket is quite complex. I believe the guy who does the K3 spares, who's name escapes me at the moment, makes brand new linkages if you can run to that.
Fri Dec 21, 2007 9:28 am
Post
Result :!: Found it, its the one with the nylon blocks for the the shaft to slide in and a piece of angle under the gearbox. Its too big for my scanner, i'll have to send it. Pm your address please :lol: I also have the drawing for the coupe's gear lever extension, although why one would'nt just cut a mini one down beats me :roll:
Fri Dec 21, 2007 9:53 am
Post
Tim,
PM sent
Many thanks
Fri Dec 21, 2007 10:11 am
Post
Alan Brit ? specialist engineering address etc in Rossa section
Fri Dec 21, 2007 5:16 pm
Post Re: Gear linkage
Hi Tim & Tim
Coupe and Rossa gearchange basically the same.
I have all the bits in stock.
I have some K3 parts as well.
Alan Britton
Alan Britton
HUNTINGDON
CAMBS
PE26 2SY
Fri Jan 11, 2008 8:24 pm
