It is currently Fri Nov 13, 2026 4:33 am
Reverse light switch
Post Reverse light switch
Has anyone got the dimensions for the reverse light switch? Mine hasn't been drilled. I'm guessing it just needs to be diagonally opposite the mini hole, but is that right? I don't really want to drill it in the wrong place and knacker it up, as I haven't got a spare.
Mon Feb 23, 2009 10:42 pm
Post Re: Reverse light switch
What does the Build Manual Say :lol: :lol: :lol: :lol: :lol: Ill try and dig mine out
Sounds sensible measure a couple of times and if you have acces to a height gauge use that as should be able to get a bit more acurate. as reverse is still in teh same place just the housing is arse about face :lol:
Never had to do that on mine as its in teh gear box, and my old A series linkage was rather different to yours, i have however seen another gtm with the same style so it wasnt a fluke :!:
Mon Feb 23, 2009 11:36 pm
Manual says rotate bottom plate 180°.
Drill and tap for switch on opposite face of
casting 180° from original position.
Pins to stop gear stick rotating require reversing.
Alan Britton
HUNTINGDON
CAMBS
PE26 2SY
Tue Feb 24, 2009 12:51 am
