Steve Shield wrote:
The Haynes manual indictates that a "re-mapping" sessition at you local ex-Rover dealer can sort this -- £26 worse off having followed the Haynes advice the, now Proton dealer, said I should change the throttle potentiometer which wasn't returning to zero properly -- I suggest you check this out physically as a first step and then clean the potentiometer with spray on stuff from Maplin etc -- that's my plan prior to buying a new pot via e-bay etc
There is a special way of resetting the stepper motor. I seem to remember this being quite a common problem. Now all I have to do is remember how you do it
Found it.
Ignition on, fully press throttle pedal steadily 6 times, ignition off, wait a minute (or probably less, I think you'll here the click, but to be sure), then start as normal.
A faulty Lamda would do it. Or an air leak.
Sounds a bit daft but have you tried it without the throttle cable connected? Just to make sure it's not sticking.
