It is currently Sun Apr 28, 2024 6:08 pm
[ 6 posts ] |
Steve Shield
Loosing Coolant
My 1.4 K series Libra is loosing water -- after short trips the header tank is empty -- no visible signs of a leak, running temp is approx 80C, no apparent sign of water in the oil and compression test shows 180 on all cylinders. The motor had done 32K miles in the donor but seems to run OK otherwise. Also the heater warms up OK. Could this be the dreaded head gasket even though the compressions are OK or maybe an airlock working its way out of the system? I'm baffled and not too keen on any long trips until reliability is proven. Anyone any ideas?
Thu Apr 09, 2009 5:22 pm |
roger
Re: Loosing Coolant
Is there steam coming out of the exhaust?
Thu Apr 09, 2009 5:46 pm |
bob snooks (835)
Joined: Sat Sep 29, 2007 3:45 pm Posts: 999 Location: SL2 4JW GTM: Libra
Re: Loosing Coolant
Passenger side carpet wet?
Don't fill the expansion tank more than half full.
If your pressure cap hasn't got a white spot on it, get one.
Thu Apr 09, 2009 11:15 pm |
Steve Shield
Re: Loosing Coolant
Possibly a little steam at start-up but nothing obvious when it s running. No wet carpet -- thinking of a leak at the heater box?? Header tank starts 1/2 full and empties down into the rubber pipe No white dot -- what's special about a white dot cap and where, other than a scrappy, do I get one? My ex-Rover dealer is now a Mitsubishi dealer so Rover parts are limited.
Fri Apr 10, 2009 11:16 am |
roger
Re: Loosing Coolant
Elise parts sell them or ebay
Fri Apr 10, 2009 11:58 am |
Steve Shield
Re: Loosing Coolant
So you order a new cap from Eliseparts, it arrives 2 days later, fit to the header tank and it stops loosing water -- how neat is that? Engines aren't my forte so I still don't understand why Whatever thanks for helping sort the problem.
Sun Apr 19, 2009 6:41 pm |
[ 6 posts ] |
