It is currently Fri Nov 27, 2026 5:55 pm
Mk1. Roll Bar Fixing
Post Mk1. Roll Bar Fixing
Next issue to address....
The rear fixings of the Roll Bar to the rear bulkhead only have one bolt fitted. I assume because the outer bold either side is difficult to fit with the angle of the bracing bar partly blocking the hole.
By easing off the two inner bolts I can flex the bar enough to get the outer bolts in then tighten them up?
Am I right that the plate they screw into is captive against the back of the bulk-head. ie its won't fall down if the bolts are removed completely?
Derek
__________________
Mk1 Rossa Q881 UOE
Fiesta Everyday Drive
Thu Sep 24, 2009 1:55 pm
Post Re: Mk1. Roll Bar Fixing
Yep the plate is captive, and yes the outer bolts are a nightmare to get in easily, i'd personally run a tap through the fixing plate to make it easier to get the bolt in by hand then just nip it up with a spanner as you can hardly get a spanner on them.
Fri Sep 25, 2009 8:44 am
Yes it was a bad design by GTM.
Would be better if plate was vertical
with bolts top and bottom.
It is possible to get bolts in but it is "fiddly".
I don't sell enough roll bars to make a redesign
worthwhile.
Alan Britton
HUNTINGDON
CAMBS
PE26 2SY
Mon Oct 05, 2009 11:05 am
