It is currently Sat May 09, 2026 7:08 pm
[ 4 posts ] |
Windscreen sealing front/rear
Andy
I've noticed on my Coupe that the fibreglass around the windscreen opening varies in thickness from say 3mm to 6mm+, especially in the corners (thicker). Do I need to remove this excess with a grinder/sander or will the windscreen rubber adapt to these iregularities.
| Tue Jan 12, 2010 10:54 am |
Pantera2075
 Re: Windscreen sealing front/rear
Thicker body means better seal - it squashes the seal onto the body and glass better, plus, if it's anything like mine, you can get stress cracks at the corners, so keeping the thickness is a good idea.
| Tue Jan 12, 2010 11:21 am |
Andy
Was just looking on the Wollies site for the rubber extrusion, my spec as below:
Front screen - 6mm glass, 2.5 - 4mm glassfibre edge Rear screen - 3mm acrylic, 2.5 - 4.5mm glassfibre edge,
So now what size rubber do I go for
Part No. R399c = 6mm glass - 2.6 - 3.2mm panel R606c = 6mm glass - 6mm panel
Obviously this is for the front screen only, but I was thinking that by the time the interior fabric is in place the panel would end up being around 6mm, any suggestions on which to use.
Sorry another question, can the extrusion be used either way (i.e. glass where the panel and vice versa), as I see Wollies don't do a rubber with a 3mm glass and 6mm panel?
| Sun Jan 17, 2010 9:50 pm |
Dino
Personally out of those two I'd go for <Part No. R399c = 6mm glass - 2.6 - 3.2mm panel> The stuff I bought was certainly symetrical (apart from the gap of course) so I don't see why it wouldn't work both ways.
| Sun Jan 17, 2010 10:50 pm |
[ 4 posts ] |
