Re: 1.5 Roller Tip Rockers
Allen7 wrote:
Don't they open the valves wider - thus more airflow (like larger valves?high lift cam)
yesss, but good tuning is not that simple - I wish it was !
... but unlike a high lift cam, do so without the side loading on the valve stem and so less wear in the valve guide?
Allen
No, definitely not the case - the reverse in fact.
Hi lift rockers are going to increase the side loading, and therefore wear, quite dramatically.
My opinion: if you're looking for the last ounce of power on a race motor they
may give you the edge, but if you expect to get reasonable mileage between rebuilds then don't do it!
