Re: Positive Feed to the Coil
reddi-eng wrote:
Is this "Pink Cable" the short length about 8" long?
Maybe !
In your original post you said the circuit tests out OK. Could you be a bit more specific?
I'd expect to see: Battery voltage, less a bit (maybe 1/2 v) at the white wire running from the ign switch
then ~9v at the coil end if it had a ballast system, or the same 12v 'ish at the coil if it doesn't.
... I've only got one one wire going to the +ve on the coil.
That's wrong for a ballast system - but it wouldn't affect the running, only the starting would be more difficult.
... Is there a relay involved because would'nt the running feed back feed the solenoid?
Well there is a relay, but not a seperate one - it's part of the solenoid.
On the solenoid there are, or at least should be:
2 large connectors - battery cable in (always live) and starter feed out.(live when you operate the starter)
A large sized spade - main feed to the wiring loom (always live)
a normal spade - the input from the starter position on the ign switch
another normal sized spade - the 12v feed to the coil (the ballast bypass) Only live when the solenoid is engaged. When the starter is not operating this connector is floating - it's neither live nor earthed, it's this feature that stops any 'backfeeding'
The above assumes a non pre-engaged starter, if it's pre engaged, ie the type with a solenoid piggybacked onto the starter the connectors are a bit different but the principle's the same.
Big But ... we haven't yet established if the system is a 'ballast type'
It would really help to know:
Age of the engine?
does it have electronic ignition?
type of coil fitted - any markings such as part numbers or voltage?
pre-engaged starter?
Any pics?
