It is currently Sun Nov 22, 2026 5:16 pm
VDO instruments
Post VDO instruments
When GTM supplied the VDO instruments for the Spyder, was a clock supplied?, or does anybody know where I could get hold of one in the same design?
Thu Jun 09, 2016 7:59 am
Post Re: VDO instruments
Try Speedy Cables I think they sell VDO instruments
Thu Jun 09, 2016 10:40 am
Not sure you'd get a perfect match. Also, if you wanted to put a clock in the main binnacle what would you take out? I wouldn't want to lose any of the current gauges. I'm going to add an oil temp gauge in an a pillar pod. I found one with a white background that looks fairly similar and being separate it doesn't matter its not identical.
Thu Jun 09, 2016 12:44 pm
Not wanting to take anything out of the main binnacle. Currently have a push start/stop button on dashboard which is extra to key ignition start so as I don't use push button this will be removed leaving a hole/space
Thu Jun 09, 2016 1:48 pm
http://www.ebay.co.uk/itm/MGF-TF-OIL-GA ... Sw1DtXH78Y
MGF ones aren't a bad match if it's not positioned too close.
Thu Jun 09, 2016 3:06 pm
