It is currently Mon Nov 23, 2026 4:10 am
New member: old questions
MikeH
Hi. I'm a new member here so please be patient with my ignorance of Cox GTM technicalities. I have just recently bought a very good but unfinished and unregistered early Cox. A few initial questions: 1 where do I find the chassis number? 2 has anyone successfully put a car through the current IVA process? 3 are there any particular problems that have to be dealt with? 4 how do I remove the body from the rear spaceframe to fit a rollcage? 5 it will probably end up as a dedicated competition car so any tips on engines would be appreciated (preferably not bike or even Mini).
Any help welcome.
Thanks, Mike
| Tue Jun 21, 2011 4:05 pm |
Pantera2075
 Re: New member: old questions
1. Hi! 2. Welcome! 3. Where are the pics? We like pics on here - it greases the helpfullness.
Anyways, Your chassis number could be anywhere. Try near front suspension tops, behind seats on bulkhead, and around the engine bay for a start. No, not an early one - I suspect it would be a nightmare. Although you might get a loophole where because you can prove how old it is (Or at least we should be able to on here) and could predate IVA dates. No, not really - apart from it being a 40 odd year old plastic fantastic. Not sure on early ones, but you will have to slit some grp and undo bolts near the lower seatbelt mounts - probably. (Others on here will be more helpful on this) Join the club and extra bits of the forum become available. I have a Toyota 4A-GE in mine, but the consensus seems to be Honda D or B series. (Wish i'd gone that route now)
| Tue Jun 21, 2011 4:32 pm |
Pantera2075
Just found this: http://fbhvc.co.uk/2011/02/18/changes-t ... -vehicles/So that's one move in the right direction. You will have to prove when your Cox was "Manufactured" and probably define "manufactured" too. IVA allegedly only applies to cars manufactured under 10 years ago.
| Tue Jun 21, 2011 6:45 pm |
turbocox
MikeH wrote: Hi. I'm a new member here so please be patient with my ignorance of Cox GTM technicalities. I have just recently bought a very good but unfinished and unregistered early Cox. A few initial questions: 1 where do I find the chassis number? 2 has anyone successfully put a car through the current IVA process? 3 are there any particular problems that have to be dealt with? 4 how do I remove the body from the rear spaceframe to fit a rollcage? 5 it will probably end up as a dedicated competition car so any tips on engines would be appreciated (preferably not bike or even Mini).
Any help welcome.
Thanks, Mike Hi Mike Welcome. First off I assume you are talking about the early (Heerey GTM) that sold on Ebay about 3 weeks ago (discribed as complete, but never registered) was it in the north east  I think. "please be patient with my ignorance of Cox GTM" Please no need to appologise..... every days a school day,  especially on this forum Ask any question you like chassis number  It may not have one if it was never finished, but as said above normally somewhere around the front suspension/ front end of the tub. IVA  If its going to be a dedicated competition car, do you need worry? I don't know of anyone who has done it how do I remove the body from the rear spaceframe  There are normally two bolts that are accessed from inside the car, as you look at the triangular plate that joins the rear bulkhead to the side sills, there is a cut out where you can get at the two bolts (expect them to be seized  ). Next check where the rear bulkhead meets the tub for fixings to the glass fibre under the rear window. Then check where the two steel tubes come out of the sides of the glass fibre front screen surround, and then finally look around the front of the lower scuttle area. Where the body over hangs the front of the tub rearward of where you find your master cylinders. Engine, Oooooooooooo....... hillclimb........ Errm. Low down torque. Some say the Honda, some say the Vauxhall, others are just mad and say keep it simple  and stick with the A series I on the other hand am quite mad, and I suggest you think outside the box, being limited buy engine sizes ect for different classes, and think along these lines... http://bonnevillestreamliner.com/2000cc-v8-engine/Where are you based  Not your address a rough area will do.
| Tue Jun 21, 2011 8:50 pm |
jules
Hello Mike
I am in a similar position to you - with an unregistered GTM kit and wondering how best to proceed. About a year ago I looked into the IVA / SVA test question in some depth, including exchanging emails with the relevant Technical Officer at the Ministry so I can give you some information you may find helpful.... (probably not)
While it is true that (as 'Pantera' suggests) vehicles older than 10 years are not subject to the SVA test, your kit will be considered to have been "manufactured" only when you submit it for registration, so an SVA test *will* be necessary if you want to use your GTM on the road. My source was quite specific on that point, so no loophole for us. The ten-year exemption apparently only applies to imported or modified vehicles.
Can a GTM be got through the SVA test? My conclusion was that it was technically possible but the cost of the test (£450 + £90 per re-test) plus factors such as the need to obtain a newly manufactured windscreen because the screen I have does not carry the appropriate "E" mark, meant that the project was not viable from the point of view of cost. Does anyone know if it has been done?
In the IVA test your chosen engine will have to meet the emission standards in force when it (the engine) was manufactured - but you have to have documentation. For me, that would have meant buying a donor mini just for the motor - another on-cost.
Of course, YMMV - particularly if you intend to construct a car to current competition standards anyway.
For myself, I am still looking for "other opportunities" that don't involve an IVA test....
Best of luck.
Jules
| Tue Jun 21, 2011 9:12 pm |
MikeH
Thanks all. Yes, it is the early Heerey car from Ebay. I think Jules is probably right. The cost involved in trying to make the car road legal looks like being prohibitive, especially when there is no guarantee that it would ultimately pass the IVA. I am happy to go down the other route and build a hillclimb/sprint car. A 2 litre V8 would be good, but maybe just a tad exotic. How about a good Rover K Series? I'm based in Berwickshire, in the Scottish Borders
| Tue Jun 21, 2011 11:13 pm |
David Large
I sprint a 1988 coupe with a Honda 1600cc twin cam engine. It is great fun but I often end up in strange classes (sports libre up to 2 litres for example) because the Honda engine was never a GTM factory option. The competition in that class can be ferocious! Where I normally sprint there is a class for modified kit cars up to 1700cc which seems more appropriate. If you intend to compete in MSA events you need to think carefully about your engine.
David
| Wed Jun 22, 2011 7:24 am |
MikeH
Thanks David, I thought that might be the case. I compete in the Scottish Lowland and in the Cross Border Speed Championships and in both cases the regs seem to suggest that the car would end up in Sports Libre. One option would be the Classic class...stick with the Mini engine and period modifications but that doesn't really appeal. Out of interest, does your Honda engine drive through Mini hubs and Mini uprights or have you modified them? What about driveshafts? At the moment my options are all open and I am vaguely wondering if using MGF components might be possible.
| Wed Jun 22, 2011 9:19 am |
You could also go B series honda, I had a D like david which was a cracking engine but the bug bit for more power and have now gone B series 1800cc, like david i too run through mini hubs and run mini suspension, I am currently trying around work to revise my rear suspension for a far better solution, but still running mini uprights.
Both of us run custom shafts, mine are modified Mini ones used for B series conversions.
| Wed Jun 22, 2011 10:40 am |
Pantera2075
My shafts are cut & shut - and sleeved, and puddle welded - all in a lathe.
They are nice and straight and look really beefy, but I have yet to test them in action.
| Wed Jun 22, 2011 10:57 am |
I did have/know a good machinist, he helped me in my early days, I had custom shafts for the D, it took a couple of atempts to get them to last, I now have a good spec for them, When i went B i used the allspeed shafts and thier larger cvs which are Mini/vauxhall hybrids,which use the large vauxhall spline the size helps massively on the strength of the shaft.
| Wed Jun 22, 2011 12:46 pm |
minitici
Hi Mike, I would think that your Coupe could run any engine and be eligible for "Modified Limited Production Cars" for hillclimbs and sprints. - assuming that you do not modify the chassis between the wheel centres, change the relative positions of the engine & transmission or change the suspension type.
| Mon Jun 27, 2011 12:12 pm |
aChildSeatInThat?
If anyone's worrying about IVA and Coupes, I may be able to offer some comfort. My 13" Coupe went through IVA in December. Failed on first attempt on a dozen items, but nothing fundamental. The dashboard was covered in copious padding and perspex over dials to mask bezels. Using a tiny steering wheel, locked into position enabled speedo visibility requirements to be met. The VOSA chap wanted to be able to see that the column was collapsible, so needed lower shroud removed. Side repeater location needed tweaking to avoid it being obscured by door mirrors when inspector stood next to rear wheel. Front indicator height adjusted by masking off lower (crazy, but it worked) Wheel arch extensions (radiused) required at front to cover Rover Sportspack rims Ridiculously narrow tyres fitted to ensure clearance. Roll hoop mounting to bulkhead needed beefing up. Seatbelt height needed adjusting (this is seat-dependent - I have MX5 seats). A bunch of changes were made in advance: Hi-Los were used at front to get lights at right height. New glass with correct e-marks. Restrictor on fuel filler. Overall, the car is about to go on the road in the next few weeks  pretty much as GTM intended (albeit 17 years late  ) once all the post-IVA tweaks have been completed - roll cage, new tyres, front bumper fitted etc. I can't take credit though - those nice chaps at Arden Automotive in Didcot did the honours. So the answer is that a Coupe can indeed get through IVA. Hope this helps.
| Fri Jan 20, 2012 1:37 am |
Good work and I see your in oxford! Neil
| Fri Jan 20, 2012 11:37 am |
bob snooks (835)
Joined: Sat Sep 29, 2007 3:45 pm Posts: 1029 Location: SL2 4JW GTM: Libra
I went and had a look at this car at the Arden open day, nice one Bob.
| Fri Jan 20, 2012 12:23 pm |
