It is currently Sat Nov 14, 2026 7:34 pm
Running a sump Guard?
Post Running a sump Guard?
Hey all
Okay I know it might sound daft but would it be possible to run a sump guard on the Coupe?
Obviously I know modifications would be needed to allow the gear selector mechanism to pass through but would there be any other issues?
I regularly go over some very bad speed bumps and drive some bad road areas (My Smart roadster regularly scrapes along the speed bumps etc :evil: )
So just thought I'd ask
Rob
Fri Oct 23, 2015 4:59 pm
Post Re: Running a sump Guard?
Hi Runk,
I made a bash plate for mine, we have bad roads if you need more I could probably arrange export :roll: but as my selector shaft passes through the box and out of the front I only need a small clearance underneath:wink: for you probably better to make a skid plate over the gear linkage where it passes under the box, you will hear it but if you can slide over the bump no damage done, I used to graunch my old Cox and also the Caterham I had :cry:
Fri Oct 23, 2015 7:15 pm
Hey John
Thanks for the reply I should have just asked you straight away you've always made loads of cool bits!
Fri Oct 23, 2015 11:20 pm
You can get a glimpse of my bash plate in the pictures of my rear steer locking arms :wink:
Sat Oct 24, 2015 4:17 am
