It is currently Sun Nov 22, 2026 7:18 am
A Series Front Plate
Post A Series Front Plate
Do I need to drain the oil before I remove the engine front plate (the one behind the timing gears)? I have an oil leak in that area and suspect that it's coming from between the plate and the block so want to change the gasket and it also has a bolt hole that needs retapping. Thanks.
Sun Jun 16, 2013 8:20 pm
Post Re: A Series Front Plate
No.
A small amount of oil will come out when you take off the timing chain cover but the oil level in the sump should be well below crankshaft height.
Sun Jun 16, 2013 8:44 pm
Great - thanks 8)
Sun Jun 16, 2013 9:39 pm
