It is currently Sat Nov 21, 2026 11:18 pm
Wheel offset and PCD
Post Wheel offset and PCD
Sorry to ask so many questions but here I am again, I am going to change the wheels on my new K3 as they are in need of a refurb at £50 each so going to buy new.
I want to stay with the 14" as the tyres are new
What is the correct offset and PCD I do not want them to stick out from the arches just flush.
Thanks in advance
Mon May 16, 2011 9:05 pm
Post Re: Wheel offset and PCD
Hi leezr160,
Wheels need to be 95.25mm PCD, ET48mm offset with 56.6mm centre. I have compomotive MO 14 inch on mine but they have an offset of only 30mm which makes them stick out past the front arches resulting in an advisory at the last MOT. It also makes the steering scary at 70mph as the car wanders around. The rear clam on mine is wider than the front and just covers these wheels so I will be having a couple of wheels made for the front with the correct offset by compomotive - they quoted me £130.00 each which seems reasonable. Standard metro alloys i.e 5.5 x 13 fit the front but look lost in the arches, I just hope i don't have too many clearance problems with the 14 inchers.
Peter.
Tue May 17, 2011 10:14 am
Hi Thanks for that, it turns out I have unmatced wheels front to back, apart from the comomotive wheels really hard to find with that off set.
So has any of you peeps got a set for sale ?? 14"
leezr160@hotmail.com
Tue May 17, 2011 10:35 am
