It is currently Tue Nov 24, 2026 11:05 pm
[ 5 posts ] |
PhilBSpyder
Joined: Tue May 17, 2016 9:48 pm Posts: 165 Location: Selkirkshire GTM: Libra
 VDO instruments
When GTM supplied the VDO instruments for the Spyder, was a clock supplied?, or does anybody know where I could get hold of one in the same design?
| Thu Jun 09, 2016 7:59 am |
kano nordie
 Re: VDO instruments
Try Speedy Cables I think they sell VDO instruments
| Thu Jun 09, 2016 10:40 am |
 Re: VDO instruments
Not sure you'd get a perfect match. Also, if you wanted to put a clock in the main binnacle what would you take out? I wouldn't want to lose any of the current gauges. I'm going to add an oil temp gauge in an a pillar pod. I found one with a white background that looks fairly similar and being separate it doesn't matter its not identical.
| Thu Jun 09, 2016 12:44 pm |
PhilBSpyder
 Re: VDO instruments
Not wanting to take anything out of the main binnacle. Currently have a push start/stop button on dashboard which is extra to key ignition start so as I don't use push button this will be removed leaving a hole/space
| Thu Jun 09, 2016 1:48 pm |
roger
 Re: VDO instruments
http://www.ebay.co.uk/itm/MGF-TF-OIL-GA ... Sw1DtXH78YMGF ones aren't a bad match if it's not positioned too close.
| Thu Jun 09, 2016 3:06 pm |
[ 5 posts ] |
