Tank has been removed. Managed to withdraw the ally rad tubes out the back of car without having to undo hard to get at P clip bolts. FYI coolant capacity is about 5.5/6 litres.
Used a ladder with wood blocks under tank and jack at one end to lower tank down after unbolting - worked well.
It was the connectors on top of the sender unit causing the problem. Earth connector tag on sender is steel and very rusty, signal connector was copper so not as bad. Emptied the tank and stood it on end tipped over slightly causing the float to flop to the top of tank - DVM used to test the resistance which measured exactly as if tank was full. Tank flat down also gave correct 'empty' reading so sender unit itself is fine.
Soldered a short fly lead to the cleaned sender tags, heatshrinked and will be painted/undersealed for further protection. Will cut off the old spades on loom side and use new ones positioned so they can be accessed under car
without removing tank. Fuel pump connector is proper sealed type so will be left alone.
Tank will be cleaned, rust removed, repainted etc. and then reinstalled.
While i've got the coolant system drained i'll probably renew some of the hoses and get rid of some of the many connections between long ally pipes and rad/engine. That'll be another post though...
Some pics on 'GTM Kit cars' Facebook
https://www.facebook.com/media/set/?set ... 262&type=1
