oldshep
Joined: Mon Apr 17, 2017 10:05 pm Posts: 93 Location: Bristol GTM: Libra
V6 OBD connection.
My V6 Libra has the Siemens ECU but the old Rover MEMS/Metro-style round 3-pin connector. It's a factory-built car so presumably the 3-pin connector can access the ECU - or is it just another unused relic from the old Metro loom? Anyone managed to successfully access the ECU? Thanks in advance.
Mon Jul 05, 2021 11:56 am |
nikvanorton
Re: V6 OBD connection.
I have a V6 with a standard OBD port that connects to both a gauge I bought and a wifi plug in 'dongle' with a phone app. I think it uses 5 wires.
Mon Jul 05, 2021 4:20 pm |
sidewinder
If the ECU is OBDII it needs the (5 wires) rectangular connector. The 3 pin round Rover one only has earth and two coms(?) wires. I'd guess yours is defunct.
Mon Jul 05, 2021 9:22 pm |
oldshep
My 3-port plug is located on the front n/s inner wing. Where is your OBD port? It's possible I've missed it.......
Mon Jul 05, 2021 11:32 pm |
oldshep
Thanks for the info.
Siemens EMS2000 is definitely OBD2 compliant, so that probably confirms the 3-pin plug is useless (thanks Sidewinder).
If I can't find an existing OBD2 socket, I should be able to make one if I can find out which ECU pin connects to which OBD socket pin - I feel some Googling coming on........
Mon Jul 05, 2021 11:46 pm |
Joined: Sun Oct 19, 2014 10:10 pm Posts: 1141 Location: Bristol GTM: Spyder
On the Mems 3 the OBD only needs three wires - pink for data signal, purple (IIRC) for ign switched 12v power and black for earth. The OBD socket I used was from a MGTF and it had a number of other pins/wires but I think these are for inputs from other stuff the GTM doesn't have like ABS controller, airbag controller etc. I mounted mine in the engine bay as that is where the ECU loom is rather than taking wires forwards.
Tue Jul 06, 2021 8:45 am |
nikvanorton
oldshep wrote: My 3-port plug is located on the front n/s inner wing. Where is your OBD port? It's possible I've missed it....... It's in the glove compartment. Mine is accessible but yours could be behind the dash. As far as I know, all OBD2 ports are inside the cabin so maybe whip the top off the dashboard and see if it's behind there.
Tue Jul 06, 2021 11:01 am |
Tim Rowe (1130)
Mine is under the bonnet on the passenger side.
I bought a Bluetooth dongle for it, as I felt it was safer than making someone sit on the front of the car when using it.
The benefits of a plastic car is the signal gets through the bulkhead without any issues.
_________________ Tim Rowe
Tue Jul 06, 2021 12:58 pm |
sidewinder
FYI the bluetooth ones continue to draw power even when ign is off.
Tue Jul 06, 2021 1:32 pm |
oldshep
I'll have a look behind the dash - I'll be very pleased if it's tucked away in there.........
Tue Jul 06, 2021 1:50 pm |
oldshep
Had the dash out today, unfortunately no sign of an OBD socket.....I'm sure it will be great fun refitting it. I wonder if my three pin socket is connected?
Still, it gave me chance to do a few jobs e.g. lubricate the wiper mechanism, run some cables, clean everything.
Thu Jul 08, 2021 10:32 pm |
mark h
I can remember reading in complete kit car an article about gtm libras when westfield stopped making them there was a yellow v6 featured the owner said the v6 engine management was different on different donor cars maybe rover 45 and 75 not sure this could be why some have obd and other have 3 pin serial port that rover connected to a machine called cobest will try find magazine article
Thu Jul 08, 2021 11:02 pm |
oldshep
Thanks Mark.
Sat Jul 10, 2021 12:04 am |
oldshep
Eureka - had a good look around under the front clam today and discovered the OBD2 socket tucked away behind the heater intake. Plugged my Bluetooth OBD2 dongle thingy in but can't connect to the app on my phone - it doesn't see the dongle as an available Bluetooth device. The socket didn't have any form of protection, so open to the elements and probably has some corrosion on the terminals but apparently these cheap Ebay dongles aren't very good - what do others use to get at the OBD info?
Sat Jul 10, 2021 11:10 pm |
sidewinder
I bought a cheapo bluetooth reader (streetwize) and used Torque Lite program cos it was free.
Sun Jul 11, 2021 3:24 pm |
