It is currently Fri Nov 27, 2026 5:47 pm
[ 3 posts ] |
reddi-eng
Joined: Mon Aug 03, 2009 11:08 am Posts: 70 Location: Worcestershire GTM: Rossa
 Mk1. Roll Bar Fixing
Next issue to address....
The rear fixings of the Roll Bar to the rear bulkhead only have one bolt fitted. I assume because the outer bold either side is difficult to fit with the angle of the bracing bar partly blocking the hole.
By easing off the two inner bolts I can flex the bar enough to get the outer bolts in then tighten them up?
Am I right that the plate they screw into is captive against the back of the bulk-head. ie its won't fall down if the bolts are removed completely?
_________________ Derek __________________ Mk1 Rossa Q881 UOE Fiesta Everyday Drive
| Thu Sep 24, 2009 1:55 pm |
advantage998
 Re: Mk1. Roll Bar Fixing
Yep the plate is captive, and yes the outer bolts are a nightmare to get in easily, i'd personally run a tap through the fixing plate to make it easier to get the bolt in by hand then just nip it up with a spanner as you can hardly get a spanner on them.
| Fri Sep 25, 2009 8:44 am |
rossabitz
Joined: Wed Oct 10, 2007 7:18 pm Posts: 157 Location: HUNTINGDON,CAMBS
Yes it was a bad design by GTM. Would be better if plate was vertical with bolts top and bottom. It is possible to get bolts in but it is "fiddly". I don't sell enough roll bars to make a redesign worthwhile.
_________________ Alan Britton HUNTINGDON CAMBS PE26 2SY
| Mon Oct 05, 2009 11:05 am |
[ 3 posts ] |
