It is currently Fri Nov 27, 2026 5:25 pm
[ 7 posts ] |
Allen7
 Fuel injection question
Still in planning stage but has anyone fitted a mini MPI fuel tank fit in a Rossa?
Would the mpi pump be up to running a tuned 1600 engine?
How good is it surge wise - trying to avoid fitting seperate swirl pot, high pressure pump (and lift pump)
Regards,
Allen
| Thu Dec 17, 2009 10:47 pm |
Andy Rossa
 Re: Fuel injection question
looking at a similar thing for myself good info on the sbd site for general plumbing swirl pot not really needed if the pump is lower than the tank and has a good supply of fuel gravity feed is best been informed the tank being tall and narrow helps prevent surge you could always foam fill it extra safety and acts like a baffle and the tank is pretty badly positioned for accident damage so safety foam would be a wise move not found any yet that can cope with E85 bioethonol fuel i would like to use so may just stick with unleaded
| Sat Dec 19, 2009 7:54 pm |
Allen7
Thanks for the information, must look at the sbd site.
So, basically don't let the level go too low and it'll probably work - Is the tank the same shape - will it fit in the same position without major modification?
Regards,
Allen
| Sat Dec 19, 2009 8:59 pm |
Andy Rossa
Should fit ok same shape as the tank already fitted to rossa as has to fit around the mini arch just the same if you have trouble sourcing a mpi tank try DMC in Willenhall they did have spares adverts in most minimags
id use a pump of the donor car to be sure of the fueling too easy source one from a scap yard
| Sun Dec 20, 2009 8:27 pm |
Allen7
Thanks for that. Looking to fit a zetec SE but intend to fit throttlebodies and probably new cams - so I guess an uprated pump is required.
Allen
| Sun Dec 20, 2009 8:42 pm |
You will probaly be surprised at how much a MPI Mini pump can support, as im sure from memory its bigger than a SPI, If you can get the part number for it you might be able to find more info with a google search on how much it flows and at what pressure. Typically speaking even the smaller pumps are good for a little over 200hp. West
| Sun Dec 20, 2009 10:47 pm |
Allen7
Sounds like the standard pump might do.
Allen
| Mon Dec 21, 2009 8:58 pm |
[ 7 posts ] |
