Re: Knuckle Joint Removal
Dino wrote:
WEST wrote:
...be careful tho make sure the rubber cone/hilo are not still under load before you remove the top arm pin.
Ah yes, that gets quite painful
The voice of experience........
Thanks for all that. I didn't consider removing the pin because I though that it would be under load so that's great
I've cheered up a bit now because I'm fed up having to redo things because of poor quality parts. As far as dust covers go I've already had to replace them on both track rod ends using some off old ends that I had lying about but which were obviously made from much better material and also the rebound rubbers have gone spongy as well
The car's 95% finished now (touch wood
) and it's high time that I updated my thread under Projects. I'll do that once I get some photos downloaded but, for some reason, my laptop and camera have stopped speaking to each other
At the moment I'm aiming for the IVA test in the Spring but don't quote me.................
