It is currently Sun Jun 14, 2026 2:04 pm
Anti roll bars measurements
Post Anti roll bars measurements
Right K3'ers I have a question for you.
I am ideally looking for some dimensions of a MGF or TF front and rear anti roll bar and as some of you use MGF bits I was hoping I could get some measurements.
so any one able to help?
Sat Sep 16, 2017 4:51 pm
Post Re: Anti roll bars measurements
I was just about to go to bed but you made me go in the garage with a tape measure!!
MGF front roll bar is 19mm diameter,880mm centre width and ends cranked down at 117 degrees 300mm long giving an outside measurement of 1080mm. There is a 10mm hole in each end 20mm in from the end. (this would be easier if I knew how to post a drawing)
Rear roll bar is a cranked shape this time 18mm diameter, centre length 880mm, cranked down each side at 115 degrees for 150mm then parallel with the top bar for 90mm, then cranked down at 90 degrees for 100mm. Overall width1290, internal 1270. The ends again have a 10mm dia hole to take a 50mm centre to centre drop link to the rear hub.
There is a picture of my rear anti roll bar in a previous post showing the end detail.
I have a front and rear going spare if anyone wants them freebies for collection.
Peter.
Sat Sep 16, 2017 11:13 pm
That is commitment Peter!
Very useful info will have to have a measure up.
Where about are you as could be interested in the front bar
Mon Sep 18, 2017 12:51 pm
Hi Neil, Junction 30 M1 just before Sheffield.
Peter.
Mon Sep 18, 2017 4:55 pm
