It is currently Mon Nov 09, 2026 7:57 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
brake ballance
Post Re: brake ballance
gtmdriver wrote:
...I used Mintex M171 pads (that's showng my age) and they felt much better than my current set up...
Ah yes, bring back asbestos, that's what I say :lol: :lol: Such a shame, it was an amazing material.
gtmdriver wrote:
Just for information all the braking system is new and nothing is siezed, sticky or binding.
Cough splutter...I would never suggest such a thing.
Sun Jun 08, 2008 12:42 pm
Andy wrote:
We use to use Carbon Metallic pads on the front of our race mini (Cooper S Calipers)and they were unbelievable, I had them for 4 seasons and they were still good when I replaced them. ...Not sure who sells them over this side of the world though.
That's very impressive, you can get them from Minispares - but they are £60 a pair! Mind if they last that long that's not too bad.
Sun Jun 08, 2008 12:45 pm
I have a set of carbon metallic pads in my Speed Triple, they are brilliant and last well too. In fact i think the discs wear faster than the pads :shock: Unfortunately i can't ride it at the moment :(
Sun Jun 08, 2008 12:54 pm
a brief outline of what ive experianced
Single circuit [when a series]
ferodo road 8.4 solid disc, std mini drums. Locked fronts very easy,
ferodo road 8.4 solid disc, std mini drums with MGBGT V8 slaves. Alot better balance, but now experianceing bad fade on track day.
Green stuffs 8.4 solid disc, std mini drums with MGBGT V8 slaves. Same balance more initial bite from the green stuffs and improved fade resistance.
Dual cicuit with Balance bar. [and now Honda power]
Green stuffs 8.4 solid disc, std mini drums with MGBGT V8 slaves. now able to fine tune the brakes to preferance, fading now a problem again and rear brakes needing adjusting very frequently, i.e twice on a track day/ every few hundred miles.
Black stuffs 8.4 solid disc, std mini drums with MGBGT V8 slaves, Black stuffs tested at one track day due to lack of pad availability and destroyied in that one track day, And after being faded a couple of times where scary, i.e no brake retardation.
Green stuffs 8.4 solid disc, My Large rear Brake kit 9 inch disc [ferodo road pads]. A lot of front bias needed on balance bar to compensate for the imbalance due to disc sizes etc, No more rear brake adjusting and more consistant pedal due to self adjusting. Brakes are more consistant upto fade point pos due to rear drums fading before front discs before.
Full Big Brake kit, Wilwood 4pots 10 inch discs. added to above, Wilwood smart pad, took a long time to bed in and felt very good, lacking in cold initial bite that i like, but was improving with more miles. Pos revisit/test, Brake balance wound closer to 50/50 on balance bar, is possible to lock all wheels, alot more control over the locking point due to increased disc size.
As above but with Green stuff pads, Initial cold bite better, and more preffered characteristics for myself.
A brief note, Brake pad bedding/disc bedding does have a huge effect and should be given a few miles to fully bed in, as much as the pads have to bed in to teh disc the disc will have to bed to the pad, i.e some brake pad material is needed to be depostited upon the brake disc, From my experiance Green stuffs when first fitted are a liitle inconsistant and you can fade them quite easy. After this first initial fade the pad appears to become more stable in its characteristics and improved fade resistance also there after.
When i do make it to the next track day i will be testing these Smart pads that i have again for the wilwoods, but at the minute my prefered pad is green stuffs. heard good things about yellow stuffs but generally from heavier cars.
looking back wasnt quite that brief :roll:
Sun Jun 08, 2008 2:23 pm
8) 8) Thanks for that.
I assume since you don't mention it, that the you used std rear shoes in the drums?
Sun Jun 08, 2008 2:59 pm
correct dino,
I looked for other materials but struggled to find anything, but with the rate i was going through them it would had been rather expensive, I use my car everyday [not at the min as its apart again for more tweeks] other projects permiting, and can quite regularly be doing 300+ miles a week at one time it seemed like i was forever replacing them.
Sun Jun 08, 2008 10:19 pm
In the carefree asbestos days i think the harder linings were VG95 (Ferodo) :?: :?:
Mon Jun 09, 2008 7:57 am
