It is currently Mon Nov 09, 2026 1:44 pm
Choke cable advice
Post Choke cable advice
Hi All,
What choke cable is best suited to the Coupe? - I recently swapped the throttle cable for a Hillman Imp number, but build manual I have offers no hints for choke.
Cable pull is to rear of gearshift, through roof of tunnel.
Many thanks.
Dan.
Sat Oct 27, 2007 8:27 pm
Post
Back in the day when i was A series powered and there were good independant auto factors i managed to find a choke cable that was a universal fit and from memory was 6 foot long and did the trick nicely, im guessing europa spares may do somthing like this or enenf prehaps fleabay may have soem universal types
Sat Oct 27, 2007 8:41 pm
Post
Thanks West, I'll give Europa a try,
Reg,
Dan.
Sat Oct 27, 2007 11:37 pm
Post
also car builders solutions has loads of stuff which you might find useful. theres a bit where you can download the full catalogue and youll find some choke cables there.
http://www.carbuildersolutions.co.uk/all_switches.htm
hows the imp throttle cable? i was gonna get one made to a measured length but if that works fine ill have a hunt for one of those?
dave
Sun Oct 28, 2007 12:19 pm
Post
If you can try and find a PTFE lined throttle cable they do exsit somewhere i cannot remeber where tho, should be nice and slick,
Sun Oct 28, 2007 6:08 pm
Post
I used a Hillman Imp choke cable and operating lever. It was designed to be tunnel mounted in the first place so it looks right.
I modified the lever mounting bracket a little but the cable went straight on.
Tue Oct 30, 2007 8:55 am
Post Re: Choke cable advice
I like the style of the Imp choke lever I may give that a go myself.
Whilst in the vacinity of the transmission tunnel, can anyone help with the sourcing of a switch for the mini hand brake lever to operate the "hand brake on" light featured amongst the triumph warniing light dashboard round cluster.
Thu Mar 06, 2008 9:04 pm
I'll be calling in to Europa in the morning. I'll ask what they can recommend.
Fri Mar 07, 2008 9:34 am
I've already got my imp choke lever. Seem the best option and they suit the look of the car. I just need to sort out a cable length, but I've got a load of jobs before then. :roll:
Fri Mar 07, 2008 9:38 am
I have most GTM spec Coupe and Rossa cables in stock.
01487 813396
Alan Britton
HUNTINGDON
CAMBS
PE26 2SY
Fri Mar 07, 2008 11:10 am
I used the Imp cable too.
Fri Mar 07, 2008 6:21 pm
