 Re: Coil spring dimensions
gtmdriver wrote: If anybody needs any real mans springs I've got
1 pair at 1.9" x 7" x 325 lbs/"
and
1 pair at 1.9" x 7" x 380 lbs/" John could you measure the wire diameter of those for me? as i wont be looking for anything quiet as strong as 325, so hopefully i can optimise the space as its looking very close from this mornings measurements West
| Sat Mar 14, 2009 4:51 pm |
gtmdriver
Sure.
The wire diameter on the 380 lbs/" spring is 9.94 mm (just over 3/8").
_________________ GRP rules!
| Sat Mar 14, 2009 6:34 pm |
Well after a little rearangement and playing about on the Jig/upright, and even thinking up a totally radical idea then reverting back I think i may have cracked it Got a potential spot for the coil over with 1.9 springs and acting direct on top of the hub  giving in theory a very close spring rate=wheel rate WEST
| Mon Mar 16, 2009 2:08 pm |
the other Tim
| Mon Mar 16, 2009 10:57 pm |
Andy
West,
Have you got any pics of your design yet or is it still a "in the head design", if you do have pics I would like to see them to see if I can improve on my own efforts.
| Tue Mar 17, 2009 9:56 am |
The design is a little of in head/scribbles in the scribble book, and drawn on CAD, as with alot of my frame so far, I even have done some fea on the bracketry to fine tune the designs a little. The top arm is custom and due to the lack of space in the engine bay I have had to come up with a cunning plan to get everything in its been a nightmare there are a couple of pictures in the members area that give a clue to how im doing the top arm.
back to the beer and a little light reading before I draw up the simplified suspension arcs to check the coilover postion/movement ideas
trying to keep options open on the coil over postion at the minute as got to consider that one day i will fit Drag slicks and they are a little wider than my road tires so need to keep some extra clearance in reserve
| Wed Mar 18, 2009 10:44 pm |
thunderossa
Hi West Brought 3 sets of 1.9" springs from e bet and the sizes make no sense They are all the same make 180 lbs 9" long 2.64 "dia 10 coils 0.36"dia 225 lbs 6" long 2.6" dia 8 coils 0.34"dia 250 lbs 6" long 2.6" dia 8 coils 0.35"dia Im none the wiser
| Fri Mar 20, 2009 4:38 pm |
gtmdriver
Normally
thin wire = soft thick wire = stiff
more coils = soft less coils = stiff
bigger overall diameter = soft smaller overall diameter = stiff
Thats how your springs seem to be working too.
| Fri Mar 20, 2009 8:39 pm |
With you specs just quickly ran it through the softwaretrickery it came up within +/- 15Lbs
So not too bad for the software i guess as it probaly a little idealistic
Been playing around with my Spring angle/postion on the CAD and the angle is giving a an almost linear movement with the wheel, Without resorting to rockers/etc you struggle to get away totally from falling rate but I have managed to get a motion of 75mm of bump @ wheel the shock is 72mm worse case not bad, just need to try a couple of tweeks to check tire clearance etc.
| Fri Mar 20, 2009 10:28 pm |
