It is currently Sat Oct 31, 2026 12:04 pm
[ 3 posts ] |
Harness eye bolt backing plates.
Ken555
Having failed the MOT on the backing plates not being adequate. At the moment they are just tacked at the corner, I plan to replace them with new 65mm square ones and weld the whole edges.
But I was wondering if people had backed them up with a plate, or if they just had the 55/65mm square plates under the floor pan.
| Sun Sep 13, 2009 3:50 pm |
Andy
 Re: Harness eye bolt backing plates.
Ken,
The plates should be beneath the car that way acting as a strengthing to the floor pan rather like using a penny washer to spread the load. When we were racing back in NZ our plates had to be 63mm x 63mm 3mm thick and had to have a radius on all four corners. They dont have to be welded but can be if you feel the urge. You should also you a Nylock nut on each eyebolt. Check the FIA standards as these will be the most extreme in which you should have to comply with.
| Sun Sep 13, 2009 8:54 pm |
Ken555
Its FIA standard plates I have ordered. 65mm square, 3mm thick.
I think the old plates are only 45mm square, so hopefully that will keep them happy once changed.
| Mon Sep 14, 2009 7:49 pm |
[ 3 posts ] |
