It is currently Sat Oct 31, 2026 12:02 pm
Harness eye bolt backing plates.
Post Harness eye bolt backing plates.
Having failed the MOT on the backing plates not being adequate.
At the moment they are just tacked at the corner, I plan to replace them with new 65mm square ones and weld the whole edges.
But I was wondering if people had backed them up with a plate, or if they just had the 55/65mm square plates under the floor pan.
Sun Sep 13, 2009 3:50 pm
Post Re: Harness eye bolt backing plates.
Ken,
The plates should be beneath the car that way acting as a strengthing to the floor pan rather like using a penny washer to spread the load. When we were racing back in NZ our plates had to be 63mm x 63mm 3mm thick and had to have a radius on all four corners. They dont have to be welded but can be if you feel the urge. You should also you a Nylock nut on each eyebolt.
Check the FIA standards as these will be the most extreme in which you should have to comply with.
Sun Sep 13, 2009 8:54 pm
Its FIA standard plates I have ordered. 65mm square, 3mm thick.
I think the old plates are only 45mm square, so hopefully that will keep them happy once changed.
Mon Sep 14, 2009 7:49 pm
