It is currently Sat Nov 21, 2026 11:18 pm
Heater fan resistor
Post Heater fan resistor
Mine has rusted out - it's the old style one as on a Metro. Any suggestions on where to get a replacement part or fix?
Fri May 20, 2016 9:58 pm
Post Re: Heater fan resistor
I grabbed a few from a local scrappy, turns out all the ones off of Ford's from 2000-2008ish that I picked up would have worked, but the one off a Ford ka fitted the best. It is for a 4 speed switch but you can just use 3 of the speeds (I use the slowest, 2nd fastest and fastest speeds)
Wiring for the metro switch on mine was;
Pink/black - high (which I attached to the red Ford ka wire)
Yellow/black -medium (blue)
White/back - low (white)
Sat May 21, 2016 7:58 am
Many thanks for that -
Sat May 21, 2016 10:21 am
