It is currently Tue Jun 16, 2026 10:51 pm
[ 3 posts ] |
It's life Geoff, but not as we know it.
crashtestdummy
Hi. Quick up date on coupe. After replacing pressure relief valve I timed the distributor to 12 degrees btdc , set plug gap and valve clearance. Connected fuel lines and with a cough she fired. Couldn't believe it, the first time I have got an A series to run first time. Just can't beat that feeling. Even the petrol leaking from the spacer to carb gasket couldn't dampen my spirits. Needs a bit of tuning but she lives. Now to the next challenge, the handbrake. Does anyone know if Mgtf, MR2 or Fiat X19 cables would fit? Yes I can get ones specific for the coupe but at around £30 each seems expensive, plus I don't want to wait months for them to be made.
| Wed Oct 14, 2020 12:56 pm |
derek hambly
Joined: Sat Nov 09, 2013 8:17 pm Posts: 55 GTM: Cox/Coupe
 Re: It's life Geoff, but not as we know it.
Hi There, I was a little surprised at this post and have checked to discover that the genuine MG handbrake cables from Rimmer Brothers are £46-80 each and there are 2 of them, and they will not fit a Coupe. My bespoke cables are a bargain at £21-00 each plus p&p at £5-00 and they will fit. I usually have them in stock, but at the moment will be available in about 2 weeks.
Derek Hambly 07814 420388
| Sun Oct 18, 2020 4:37 pm |
crashtestdummy
Hi, sorry I must have been miss informed, no offense was intended. I did have the original set up that used the inner fixed and the outer moving however I found the system less than ideal and came up with a system that has the outer fixed to a bracket fixed to the top ball joint bolt and the inner attached to leaver in back plate. Where it will work will depend on whether I can get cables long enough.
| Sun Oct 18, 2020 9:39 pm |
[ 3 posts ] |
